Honeywell 4200 3879 001
1 May 2020
All
Hope you well and safe,
I have this old thermostat and with the glow worm 35ci combi boiler.
This thermostat seems to be not working.
It has three terminals
wires are connected
2--> BLUE
3 --> YELLOW
1--> RED
I checked for the voltage but there are no volts on any of these terminals
Can any one help
I checked the thermostat with multimeter and it does change reading with dial.
Pls help any ideas.
cheers
mik
You should have voltage between 1 & 2, if not then I suspect your programmer is broken. If there's no power coming in, you won't get anything out
programmer in boiler there is a power in to boiler
Do I need to have a look at the control board inside the boiler ?
