Honeywell ADE Reson 8 bell box - connection help required
31 Jul 2013
Leeds
I have purchased a new Honeywell ADE Reson 8 bell box which excluding the battery has five terminals:-
Stb -
Trig -
Hold off -
Hold off +
Rtn -
How should it be connected to the existing control panel using the available four wires ?
Notation on control panel is :-
SA bell hold off -ve
SA bell anti-tamper -ve
Bell power -ve feed
Bell hold off supply
:confused:
stb - ve strobe trigger, link to bell trigger if yu only have 4 core cable
trig - ve = bell power -ve (bell trigger)
hold off - ve = SA hold off - ve (bell hold supply negative)
hold off + ve = bell hold off supply + ve (bell hold off positive)
rtn -ve = SA bell anti tamper - ve (tamper return)
Oasis
Oasis
Oasis. Thanks for your prompt response
Please confirm if I have got this connection plan correct.
Stb - = Fix an extra lead from this terminal to Trig- terminal
Trig - = Bell power -ve feed
Hold off - = SA bell hold off -ve
Hold off + = Bell hold off supply
Rtn - = SA bell anti tamper - ve
yep thats right, unless your cable to the eternal siren has 6 cores then use the strobe connection using another one of the spare cores.
Oasis
Thanks for the confirmation and have wired as you said. The supply cable from the control panel has only 4 cores red, black, blue and yellow.
Next thing is to activate the system and I hope you can on advise the appropriate connection sequence.
1. Control panel mains supply on / off
2. Control panel battery - and + terminals in
3. Control panel switch on / off
4. Bell box battery on / off pin terminal.
5. Bell box timer settings :-
J6 test
J5 20 minutes
J4 10 minutes
J3 5 minutes
Also what should I expect to hear if all is well
