honeywell cm67 timer wirless
11 Jan 2011
Derby
please help I have an ideal boiler and a honeywell cm67 wireless timer that connects to it and ofcourse controls the heating temperature, I have set it to come on at 5am every day and it states on user guide that u move the slider to auto for the heating to come on at my desired time but I am finding that it constantly stays on and it getstoo warm were as I would rather that it comes on at my desired time any idea why it is doing that?
The CM67 is a programmable thermostat so it does not go on and off like a timer. You programme it to have up to 6 different temperature settings through each day. With the default settings, your heating during cold weather would be on all day because the minimum setting is 18C mon – fri and 21C at the weekends. Have you adjusted the set temperatures?
Hi mikely I have not set temp as can set 6 different temp through out the day but only prefer to keep the same temp all day so cancelled the other 5 settings for temp but once I programme the cm67 for my heating to come on at 5am a then slide the dial to auto but when obviously I want the heating to come on at 5am it comes on before my set time as obviosly the temp drops how can a stop that not to happen?
If you have cancelled the other 5 settings then the thermostat will be set to the same temperature all the time, hence the heating stays on. If you want the heating to go off at, say 10pm, set program 6 to 12C at 10pm.
1. What time do you get up in the morning?
1. Is 5am the actual time set for period 1?
2. Do you have optimization ON (parameter 15:Op=1)?
4. What is the last time/temperature setting?
