Don't need the blue so tape it up. Red should be one I think and yellow 3.
The wiring diagram with the Honeywell is very good.
What system are you putting it on?
AL
Why overkill in a Y plan? The cm907 does everything you need to control the heating times and temperatures. What more could anyone ask for?The Honeywell cm907 is a chronotherm programmable stat. I would say that it is a bit overkill for the Y plan system that you have.
Are you suggesting that people with Y plan do not need set on/off times?A cm907 is more suited for a combi boiler installation or even an air conditioning unit - where set on/off times are required.
So you either set your existing programmer to continuous CH, and let the CM907 control times and temperatures; or you wire the CM907 back to a permanent live in the wiring centre, missing out the existing programmer completely. The existing programmer will continue to be used to control hot water times, which do tend to remain fixed.Although it will work on the system you have - it will not bring the boiler on if your programmer is not calling for heat.
Thanks D_Hailsham& Mario for the info, any idea what the wiring connections would be from the existing room stat to cm907 are they as been quoted earlier by Mario 500Why overkill in a Y plan? The cm907 does everything you need to control the heating times and temperatures. What more could anyone ask for?The Honeywell cm907 is a chronotherm programmable stat. I would say that it is a bit overkill for the Y plan system that you have.
Yes, as Mario said earlier: Red to A an Yellow to B. The blue wire is not needed and should be made safe (insulating tape) at both ends. I would also move the red, at the other end, to a permanent live - normally terminal 1 in the wiring centre. This prevents the accidental turning off of the heating at the old programmer, which still controls hot water times.any idea what the wiring connections would be from the existing room stat to cm907 are they as been quoted earlier by Mario 500
I think you will find that the OP has already bought the CM907.Why have two programmers? what on earth for? Just my thoughts, but I personally would install a basic room stat with a digital display.
