Evening All
I switched on the UFH in the Kitchen at the weekend and initially had problems. Found that the Grundfos pump was buzzing. So dismantled it and the impellor had seized but thankfully not seriously. Once freed, all now appears to be working ok.
However, last year, when I initally installed the floor, I wired in the Honeywell CM907 but didn't set up all of the options.
I've just been into the installer menus to switch on Optimum Start and noticed 2 other options that I hope people might understand.
In the second installer menu, there are some options for using thermostat for specific applications. It says that if using a gas boiler or zone valve, you should leave at default settings of 6 cycles per hour and minimum on time of 1 min, but if you are controlling an oil boiler, you should change to 3 cycles per hour and 4 mins minimum on time.
The CM907 in the Kitchen is controlling a zone valve, which then switches an oil boiler.
Do you think I'd be better to change to the oil boiler settings or leave? The boiler is quite old (Camray 5) and so might prefer longer run times?
And then, in the final setting of menu 2, there is control for pump exercise, which is default off. Is this as it sounds and occasionally spins the pump to stop it seizing. If so, I will switch on. Any idea how often it does this?
Hopefully someone can help. Whilst I am happy with Honeywell controls, they are not always great at explaining functionality.
Steve
Steve
