Hi all,
I'm looking to replace the old timer switch on my 15 year old oil boiler. The timing part of the existing switch is broken and I just use the rocker switch on it to turn the heating off and on.
Mine is a basic boiler that heats up water and pumps it round the house and into the hot water cylinder. No separate part for heating hot water by itself.
I asked a plumber about the honeywell cm927 and he said 'this will only work with a combi oil boiler and will be ineffective on a conventional'.
I couldn't see why this was the case as surely it only needs to switch a relay, basically what i'm doing at the minute with my finger on the rocker switch on the old timer.
Sorry for the long message but I just want to be sure I'm getting the right thing before I buy it now, he's put doubt in my mind !
I see in the online manual wiring diagram, section 4
- a. Burner (direct control)
http://www.honeywelluk.com/Documents...l/pdf/1069.pdf
I assume this is how I need to wire it and the plumber is talking nonsense ?
Sorry again for the long message
Thanks,
Mark
Thanks,
Mark
