Honeywell CMT927 Wiring question
23 Dec 2006
Warwickshire
Hi
I have a conventional condesing boiler running off a timer unit and sunvic tlx201 thermostat in a 2 year old house
The thermostat has wires to COM, DEMAND and N
How do I connect up the reciever/relay unit to these 3 wires when replacing the 'stat? I am planning on just setting the original programmer to permanently "ON" for the CH and only then using that origianl timer unit for the HW
cheers!!!
Sunvic = Honeywell
Com = L
N = N
Demand = B
If that does not work, reverse the L and B wires - it was wrongly wired to begin with.
Also connect L to A in the receiver
That's OK until someone accidentally turns the CH OFF at the programmer. A better way is to disconnect the wire from the CH ON terminal of the programmer and connect it to the L terminal.
Hi there
Well, finally got around to fitting this today. Relay lamp illuminates in repsonse to transmitter but boiler is not responding....
I tried swapping the two wires (L & B) but still nothing. Am I missing something?
many thanks!
cheers
Paul
