Honeywell DT90E problems!
1 Mar 2011
West Glamorgan
Hi
I have just installed a Honeywell DT90E thermostat today to work alongside my Worcester Bosch Greenstar 30CDi and a Plumb Centre heating controls.
All wired in correctly, but when setting the temp to say 23.5 the actual room temp is displaying 20 without any changes to this temp when the central heating has been running, and it seems as if the boiler is working really hard to provide 23.5 when in reality it is only showing 20
Hope this makes sense and is this normal? or does the thermostat need to be configured at the moment it's all factory set
You have to set the parameters by following the instructions.
23.5 is much too hot anyway.
Where is the DT90E located?
Is there a Thermostatic Valve on the nearby radiator?
If so, what number is it set to?
Does the boiler keep going all the time?
What temperature is the boiler set to?
Why set the stat to 23.5C?
If, with the actual temp at 20C, you set it to, say 18C, does the boiler stay off until the temperature has dropped?
Does the boiler stop when you turn the stat right down - what temp?
Does the boiler start when you turn the stat up - what temp?
Hi
Yes I just set it to 23.5 just to get the room heat up quickly so I could see if the thermostat would reflect the change in temp so that I could see that it's working
Yes I set the parameters by using the arrows to select the room temp 23.5 which flashes and then reverts back to the actual temp 20.
Temperature Enquiry - By pressing the down arrow shows the set temp 23.5 which flashes and then returns to actual room temp
On the heating demand indicator only 1 flame was showing not sure if this is normal?
Perhaps its as simple as your rad cant get the room any hotter than 20.
Do I need to change any of the parameters in installer mode on the thermostat? or can I just leave it all as default?
It is located in the hallway, and there is no TRV on the radiator nearby
On the boiler the central heating temp control is set to number 6
Turning the stat up wont get the space hotter any quicker.
The stat would be better in the lounge where you can control the living temperature.
ok thanks all, unfortunately the stat can't be moved due to the existing wiring etc
With regard to the installer mode on the thermostat do I need to do anything on here or leave it all to default?
