Hi everyone, Im new here.
I have had a new honeywell DT92E Thermostat fitted to my new combi boiler system, and with the weather starting to turn I thought I better work out how it works.
I read the absolute useless instruction guide and this makes hardly no sense whatsoever, only giving brief one lines on what various things do, not how to actually operate it.
From what i can gather the normal display is the current room temperature. you then press the up or down arrows to change the temperature you want it set at, and press the on/off button so the flame is displayed and it should then come on, however lastnight, room temp was at 20c, and i set the temp at 28c and turned it on, left it 15 mins and nothing happened, the boiler only fired up when i set the temp to 35c.
Does anyone have experience of this system and the best way to use it?
In the instructions it also goes on about frost protection?? what the hell is that all about??
All i want is to be able to set my heating to come on and go off at certain times of day, and i dont seem to be able to do that?
HELP!!!
HELP!!!
