Honeywell EP2002 - best replacement ideas please
27 Oct 2012
Kent
Have decided to update timer for our boiler - current Honeywell EP2002.
Can someone recommend a better, more reliable timer please.
Many thanks.
Adrian
the EP 2000 could be used as a wiring centre also and if your has then no matter what you replace it with will need a fair bit of rewiring all new programmers use an industry standard backplate and can be swapped easily but the EP 2000 doesnt use the new backplate, I fit ACL programmers just because they are easy to programme and use but there are loads of good ones on the market but some are just too complicated for the average user
