Honeywell Galaxy G2-20 Alarm Internal Sounder
4 Dec 2011
Merseyside
Hi
I am trying to install a internal sounder to my alarm system, the sounder has two connections but the panel only has one for a internal sounder, it is labelled on a diagram Loudspeaker negative, I am assuming you simply wire the negative connection into there and the positive into the positive aux point.
Is this correct?
Matty[/u]
self activating , it activates when hold off is removed or wires are cut, removing hold and also tamper singnal is generated within the panel
Definition of ACTUATE
transitive verb
: to put into mechanical action or motion
Definition of ACTIVATE
transitive verb
: to make active or more active
See the difference?
Clue was how and when you were taught oh little one.
i be corrected, im sure i've read somewhere that it Said its self activating .??
Thanks for the correction
