Hi. I'm finishing the install of my G2 system and have got to the point where I configure the users (all zones and detectors are up and running).
The system has up to 23 users as far as I can tell but I only want to have two users (me and my missus) or ideally one if we can both essentially be the same user (might be complicated if we want to use prox tags as I guess you have to can't have one user with two prox tags).
I guess my question's are:
1. What level should I assign my user rating to? Presumably we need a master (L3) user so that might as well be me?
2. What do I do with all the other user profiles that the system can accommodate? I might be wrong but it seems that all the users are active by default?
3. Pin numbers. I tried to configure user1 as an L3 user with a new password (not the default 1234) which worked fine but then found I could still log in/set/unset etc with the old 1234 password. I can't see how this is possible unless it was simply logging in as another user with the default code. How do I prevent this?
Sorry for all the questions but I've poured over the manual that came with the system and other guides that I have been able to find online but can't find any answers.
Cheers,
iep
Cheers,
iep
