Honeywell Motorised Value Rattles and makes a loud noise
21 Mar 2005
My Honeywell 3-way motorised value makes a loud rattling noise. If I turn the pump up, the noise increases and if I set the pump to 1 it doesn't rattle so often. This started happening after I replaced my hot water cylindar.
Anyone know what the problem may be?
Could it be the pump making that noise and I think it is the valve?
The noise travels all round the house!
Brian
Use a big scrwdriver on the pump and valve as a stethoscope. More likely to be the pump.
Wilhelm, I don't see the point of your link or your sham German accent. As for the site the link connects to, many people would consider much of its content distasteful and indeed offensive.
I accept of course freedom of speech and the right to access whatever web sites one pleases, but I cannot see why you are bringing this sort of material to our attention. It certainly has nothing to do with plumbing!
star trek?
i was trying to say, that maybe as the problem occurred , after cylinder change...that maybe air lock. been to noisy pumps before....no wasser...in these instances it was blocked cold feed.
:rolleyes:
OK, good point about the possible problem, but I think your way of expressing it somewhat bizarre. And what about the jrbooksonline.com site that you linked to? Are you a fan of that sort of stuff?
