Hello all, this is my first post…
I have two Honeywell Motorised Valves. The first is a V4043H1056 (22mm, 5 wires; Brown, Blue, Orange, Grey and GRN/YEL earth. The Second is a V4043H1106 (28mm 6 Wires; Brown, Blue, Orange, Grey, GRN/YEL earth AND White.
I have some questions, probably quite simple, but I just want to get a thorough understanding before installing….
From looking at the Honeywell Data sheet http://www.plumbnation.co.uk/site/h...h/Honeywell V4043 Technical Specification.pdf I see that the “De-energised state” of these vales is closed. In laymen’s terms does this mean that when power is NOT applied to the valve then the valve is closed and thus not allowing water to flow through?
I presume that when connected to a power source (Brown to POS, Blue to Neg and Yel/Grn to Earth, the valve will open allowing water to flow through. Is this correct?
Can someone also please tell me what the Orange and Grey wires are for and also what the White wire is for (V4043H1106 Only)?
Many thanks in advance, Ashley.
