- Joined
- 17 Sep 2004
- Messages
- 465
- Reaction score
- 10
- Country
I have a Honeywell ST6400C programmer for heating & hot water.
Most of the time, hot water is set to 'off', and when I need hot water I press the 'extra hour' button for a full cylinder of hot water.
However, someties when I hit the button, the entire programmer goes off - all lights out, display goes blank. After mayber 2, 3 seconds there's a click & it restarts (back at previous setting).
This does not always happen, and I can see no pattern as to when it will work, or cut out.
Usually pressing 'extra hour' again works, though occassionally it will cut out a 2nd time.
My questions are:
1) what might be the cause & is it an easy fix?
2) if it needs replacing, I'm sure it is an obsolete model, but if there's a comparable replacement model, does it need a sparkie/heating engineer to change (lotsof wiring inside?) or do they unscrew, pull off, push on repacement and screw up?
Cheers.
My questions are:
Cheers.
