Honeywell Room Stat 4200 3879-001 - Replacement ??
13 Jun 2005
Monmouthshire
I have a Honeywell Room Stat with a number on its cover 4200 3879-001.
Its has Brown base and Beige cover, with four terminals and only 3 of the 4 used.
Any clues of a replacement for this today.
thanks
Ok,
The timer/programmer maybe alittle ancient too.
7 day programmer - 'Drayton Tempus Severn'.
Boiler - 'Worcester - Greensaver force vented' - fitted Nov 2012
Two motorised valves - Open/Closed
Airing cupboard Hot water tank has a Stat too.
Is that of any use.
Could suggest a replacement Programmer too.
Sorry forgot to mention,
All upstairs radiators have thermostats, set on the low side basically warming the rooms on a cold morning.
Sorry again,
Another thing I forgot to mention,
There is also a Multi Function/Speed pump in the airing cupboard, fitted same time as new boiler by Brit Gas.
Would having a pump make and difference to the wiring of the DT90E as advised above by Dan..
thanks
