Hi - I have a CH and hot water system controlled by a Honeywell ST6300A thermostat unit.
In its most basic functions it works fine -ie if we turn either the hot water or the CH to on, it comes on and when we switch it off (manually) it turns off.
The problem arises when we try to use the timer function to run the CH at specified times during the day without having to manually get involved each time. Basically it simply doesn't turn on 9 times out of 10 when it should - and if it has turned on, then chances are it won't switch off when it should.
There appears to be nothing wrong with the water/heating system itself and the thermostat part of the Honeywell system works fine (in terms of temperature control) - it's just the timer is not happy.
Has anyone seen this before or have any idea how to fix it?
There is a reset button on the front of the unit but I haven't pushed this yet as I'm not sure exactly what it'll do.
Thanks in advance for any help/ideas/comments
