Honeywell ST799 Programmer
Status
Not open for further replies.
29 Mar 2009
Hi
We do not have any hot water.
Our boiler, a Worcester, is working as the central heating is blasting out, but we do not have any water. The instruction book advice is to clean a strainer which has been done, we have also repressurized the Megaflow as per the instructions. I have looked at the pipes and a hot pipe comes from the boiler to a silver Honeywell box marked "hot water" the other side of the box the pipe is cold. The Honeywell programmer is on and the Hot Water light is on. If the Heating slide is switched off on the programmer the boiler does not fire up to heat the water.
Any suggestions.
I really dont know why you think that you should make THREE postings on exactly the same subject! It wastes forum space as well as my time!
Hi Tony
Sorry about that. I posted three times because I was not sure where the problem lay and I wanted to cover all the bases.
Thanks for your advice, and I promise I will not do it again.
Status
