Hi
We had new system installed about 18 months ago: Vaillant ecotec plus 624 system boiler, 2x 2 port Honeywell valves (one for hot water and 1 for heating) and an ST 9400C timer.
Have just noticed that when I programme the timer, if I set the hot water to come on at a time later than the heating time on, then the heating valve does not change position and stays in the "off" postion - no hot water. The indicator light on the timer remains on.
With the heating switched to "off" on the timer, or at a time on later than the hot water, then the valve opens as expected!
I suspect this could be a simple wiring fault but cannot believe that I have not noticed this before.
Any other suggestions please?
