Have a question about the Honeywell V073a mid position motorised valve.
My system is vented, fully pumped Y plan with a Potterton Suprima non condensing boiler – small house – 7 single panel rads and 125 litre HW cylinder. All works fine at the moment however…
I noticed that when the CH and HW are on together and there is definitely a call for heat from both, the system seems to give priority to HW. I only found this by doing the following several times…
Cylinder and rads are cold (not used for a few days), turned HW on (normally takes about 40 min to heat fully cold cylinder this time of year), some 10 min later decide to turn CH on. Rads begin to heat slowly. 5 min later turn HW off – there is still call for heat for cylinder as water still cold – boiler goes off (which to me indicates it has only been heating the cylinder despite slight warmth in rads?) then cycles pump and fires again for CH only as HW is now off.
This is not causing any issues and the boiler is serviced yearly but Im just curious – does the v4073a somehow give priority to the HW when there is a call from CH and HW together (this would probably make sense in most circumstances?)
Thanks…
Thanks…
