Hi, everyone, this is my 1st post...
As the title says, the tumble dryer function of the machine doesn't work. The drum rotates and the fan & pump (to the condenser?) run, but the element doesn't get hot. There is no voltage at its terminals either. I think I've identified the thermostats (if they are the other parts connected by wires on the aluminium housing that the heating element sits in) and there is no voltage across them either. The heating element has a resistance of 39 Ohms. Can anyone suggest what actually might be causing this fault, & what would rectify it?
Thanks, Bren
Thanks, Bren
