masona said:Thanks Breezer, doesn't sound like a coin noise but having said that, it may sound difference if it is !
masona said:Is the counterweight on the top of the machine like a brick ?
Can't do it the front panel is spot welded and can't do it underneath because the bottom counterweight is about 50mm from facing the front panel and the bolt is 75mm long. I also need to drill the remaining bolt what left in the holebreezer said:we always used to take the drum out through the front (obviously remove front panel first)
masona said:Damn I only have a small inspection panel at the back so look like I going to have move the drum from the top
