Can only be a few things (assuming the programmer is turning);
1) Drum bearings are seized - Can you turn the drum by hand ?
2) Motor not turning - Can you hear it running when its supposed to ?
If not sure you will have to take the back off. If the motor is not turning , the brushers may be worn down.
3) Has the belt broken or is it slipping when the motor turns ? Replace or
tighten it.
