Hoover 1300 Special Edition (SE234)
My son has the above washing machine and told me it was 'smoking'. When I went to have a look he told be the smoke was inside the drum and came out when he opened the door. On checking his machine I can feel a 'tight spot' when I rotate the drum by hand. It will spin free and then hit this tight spot. There is a 'rubbing' noise when it hits this spot. It is not a grating noise that you would get with metal on metal contact. It seems as if the steel drum is catching on the plastic housing that it runs in. I can't feel any 'play' in the drum to suggest that a bearing has failed, but that may just be because the weight of the drum is preventing any excess movement.
He is a young disabled lad living on his own without much money so we're hoping it is a fixable problem at a reasonable cost. I am not able to do this type of repair myself so we will need 'professional' help, but would appreciate some suggestions as to what the problem is likely to be.
Thanks in advance for your help and advice.
