Yesterday my machine didn't pump all the water out after a spin cycle, so after taking top off & the back, I found that there was current going to the water pump but the pump wasn't working (nor could I hear it trying to turn against an obstruction) so I'm assuming the pumps burnt out.
Then I found that the Circuit board "on/off" micro switch had given up. So the way of getting it to start after selecting the Wash cycle was to just keep pressing the micro switch.............& this worked OK on a "Fast Spin Cycle" I tried this a number of times without the top or front on the machine.....& noted a slowly rotating disk at the front operating levels & while this was working OK the Cycle finished OK....then on the last run, the mechanism "Clicked & whirled" but the disk did not rotate....& the cycle did not finish correctly..........is this a 3rd defected in a couple of hours ? Paul
