HOOVER AL130 NO WATER
21 Aug 2005
West Midlands
NO WATER COMING IN NO NOISE AT FILL VALVES,
ONLY SETTING THAT WORKS IS THE SPIN SETTINGS,
THERE WAS TIMES WHEN THE DIAL WENT TO STOP ON ITS OWN,
WATER TO maschine FINE, PIPES CLEAR,
ANY HELP WOULD BE GREAT.
______________________________
moderator
please note 6
the simplest cause of your problem assuming that it does not take either hot or cold, is that there is a fault in your drain pump circuit. it could be that the pump itself is no good (after thought, can you hear the pump running during the spin cycle?). if it's not your pump then i can say that i've seen loads of these machine blow the triac on the main p.c.b. which controls the pump. if your machine is less than five years old then you'll get hoover to give you your "free" parts in exchange for paying them approx £80 to fit them. in the case of a board then it's worth it assuming the rest of your machine is o.k.
