Have had some problems with my w/m as follows:
1. a couple of months ago I noticed some water leaking through the front right (near leg area). Water was visible on the floor tiles but could not trace it when I opened the back of the w/m. I also noticed white residue marks on the paper cover at the bottom; near the front bottom right (detergent drawer side).
2. 10 days ago the w/m would not spin at all, not even to wash. Called GIAS, the engineer changed the motor but after 4-5 washes had the same symptoms; the engineer came again and changed the motor again!
3. Had another 3 washes but the w/m will not do the final spin. When I turned the program dial a full circle to the same position it did spin the clothes, but it did not feel or sound as normal, as if it was spinning at 800 and not 1100. This time though there was water leaking as in 1 above. In the first of the 3 washes the machine did not use the softener!
We are calling the engineer tomorrow again but I would appreciate a second opinion; is it time to get another one (had this one for 4yrs +) or is it a case the engineer did not find the cause of the problem yet?
Cheers
Cheers
