Hoover Electron W/M leaks from rear outflow when filling
7 Feb 2005
Really annoying intermitent problem with this machine in that sometines when it fills it spews water out the back through what appears to be a release outlet (hole) at the back of the machine.
Also noticed that sometimes it goes to sleep for 15/20 mins during a cycle (partcularly before spinning), but tonight as I type this it's done a cycle with no probs whatsoever!
I have done some research, and it doesn't appear to have a filter; I have also taken off and checked all the pipes (to and from pump etc) that I can find and none were blocked.
Any ideas/comments gratefully received!
kevplumb said:
if you check breezers posts he photographed and labeled the inside of his ;)
:cry: but mine is a hotpoint, and i only (so far) showed the top
