Machine starts. Rinses 1 led on, moves to start washing, 2 leds on, then just does nothing. I checked the programme selector, working OK. Could the pcb be stuffed? Anyone with suggestions! Where can spares be sourced.
I got a good answer from travelman. If you can clean mother board 1st with circuit board cleaner ( you can get this in Maplands). This board is in the door panel easy to get at.Let it dry off before re assembling.Good luck.
If your machine was registered when bought and you have receipt then parts are covered free for 5 years. I would remove mother board from machine note connections and spray with WD40 then spray with circuit board cleaner.Take care to let it dry off completely before refitting.
IF YOUR DISHWASHER STARTS, FILLS WITH WATER THEN STOPS WITH BOTH FIRST 2 LEDS ON AND AFTER 5MINS ABORTS, I HAVE THE SOLUTION, ITS??? THE LITRE-COUNTER SWITCH! EASY TO FIX AND COSTS NOTHING BUT HALF AN HOUR OF YOUR TIME IF YOU KNOW WHAT YOUR DOING
the litre switch is a small switch( looks like printed circiut board size of £2 coin ) located in middle of flat plastic water container in left hand side panel from front looking, undo rear and front screws to move side panel away to reveal water container at top inbetween sponge soundproofing, it has 2pin plug with 2x black wires on it, cut theplug off and solder 2 wires on to board. its water on pins on plug which cause bad connection ( even if it looks new). i have done this loads of times and it works.IF YOUR DISHWASHER STARTS, FILLS WITH WATER THEN STOPS WITH BOTH FIRST 2 LEDS ON AND AFTER 5MINS ABORTS, I HAVE THE SOLUTION, ITS??? THE LITRE-COUNTER SWITCH! EASY TO FIX AND COSTS NOTHING BUT HALF AN HOUR OF YOUR TIME IF YOU KNOW WHAT YOUR DOING
hooverengineer - Can you provide a bit more info, e.g. where the litre counter switch is located and what to do.
