Hoover HF7130mUK Does't Drain: Pump ok, No Blockage
16 Jan 2007
Norfolk
I've got an problem with my mentioned washing machine.
It started about a year ago with intemitant stopping half way through a cycle run the same again and it would be ok. The issues has moved on and it now permanently does not drain. Pump clear debris catcher not blocked drain hose removed and is also not blocked. If an external supply is applied to the pump it spins and drains the machine.
Could it be the PCB or Rotary switch? If so what do I look for? :?: :confused:
Just took the control module out to look for failure none obvious connected it back now working, could it be connection or timer? :?:
