Hoover hnwl7166 lifter paddle
8 Nov 2012
Hi guys new here, I have a problem with my hoover nextra washer dryer model number hnwl7166. The lifter inside the drum has become detached I have ordered a replacement can someone please give me some idea how it is fitted to the drum as it looks as though it is held with a screw coming from the outside of the drum.....
Remove the filter or heater that's how to get the screw out.
Found the answer......
There's a screw holding each paddle in place, as well as the lugs on the paddle. You can get to the screw by removing the drain hose from the bottom on the drum, and the paddle will then be free to slide out
