K
kittgs
I have a Hoover Washer/Dryer which has an issue where it gets stuck mid cycle on one of the washes. Unfortunately it is the cycle we use the most which is labelled as 4 (40deg non-fast colour wash). It gets stuck almost exactly half way between the 4 and the 5 on the dial. The only way to progress is to click the dial around.
The point where it is stuck seems to be where it 'agitates' (for want of a better word) the wash back and forwards. It makes various whirring and clicking noises and seems to function fine but just never progresses. This is whether it is on 'economy' setting or not. It always stops at the same point on the dial (which I have now marked).
If I click it to the next 'notch' it starts draining (as expected), I felt the temperature of the water coming out of the machine and it is stone cold. So my first guess was that the element was gone.
However, if we set it to a 2 or a 3 wash (90 deg or 60 deg) it progresses past the same point on the dial with no problem and the water is nice and hot.
The machine has both hot and cold inputs so I imagine the heat on the 60 or 90 wash could be just from the hot tap? (although I wouldn't imagine our hot water is at 90 degrees!)
I have ordered a new heater element as that is cheap enough even if it doesn't fix it. I am also planning to clean the thermostat with a little descaler (the thermostat had a bit of calcium build up on it but not much).
My second guess would be the (snap disc) thermostat which seems to have two inputs and two outputs (4 terminals) so I'm guessing there is one thermostat that operates at a certain temperature (40? )and another one that operates at a some cut-off temperature (90?). However, the thermostat is a bit more pricey so I don't want to replace that unless I'm more sure it has gone.
Once I manually click it on one notch the rest of the cycle always runs through fine and it spins OK etc. so no problem with the motor as far as I can tell.
Any suggestions for further tests, etc? I have pictures of the dial and the thermostat if that is any help!
Thanks in advance for any help
Kitt
Kitt
