Hoover Vision HD
16 Apr 2011
Fife
Hi folks,
Im new to the forum...good stuff.
I have a Hoover Vision HD and the plastic sections inside the drum which push the clothes around have came adrift due to the screws loosening off and there has been some noise, which I am assuming is the screws getting jammed between the drum and the outer casing. Do I need to remove the drum to re-attach these plastic sections?
Thanks in advance for any help.
Arch007
No new ones just clip in older ones are screwed from under the inner drum. You can cable tie them in.
