Hi, as I closed the door of my Hoover W1120 washer I noticed that the earth leakage switch on my fusebox had tripped. I hadn't even selected a program or turned the machine on. The fault is now present whenever the machine is connected to the mains, with all controls 'off', regardless of whether the door is open or closed.
Everything appears normal under the lid. I did some basic checks and discovered that the fault is on the live circuit. The live input goes to a terminal on the pressure switch. Disconnecting that terminal, not too surprisingly, stops the problem so it's somewhere further along the circuit.
On the possibility that closing the door had caused a slight pressure change in the drum and activated the pressure switch I looked inside the switch but saw nothing wrong, with no evidence of burnt terminals and the diaphragm in good condition. When blown into, the switch makes two clicking sounds a second or so apart and the same when the pressure is released, consistent with the two internal switches being operated.
The fault conditions have now changed. The washer can now be left connected to the mains but as soon as I move either the dryer or program knobs the short occurs, even before I use the 'on' switch. The washer worked normally when used a few days ago.
Any further clues appreciated
