Put on a high heat cycle and it stopped before it was complete. Seems to be more water in there than there should be now and it won't spin on any cycle. Any advice please?
If there are no error codes or flahing indicators then check the waste pump for obstruction and motor brushes are not stuck or worn away if you have that type of motor
As above, check the brushes. I had a Meile that would go through the motions but refuse to spin (it would slowly rotate in both directions during the wash, as normal) . Someone recommended that I check the brushes. One was completely worn, the other one almost looked like it was new.
Thanks. Think there' an issue with the filter. I can unscrew it but it won't budge so I reckon it might have a sock or something in there jamming it if that's even possible? All the water drained out and the machine spins as normal now but I can't get the filter out, and it leaks water when draining.
