Hoover washing machine (Error 22) (Ed.)
10 Mar 2025
HI
I have a Hoover washing machine, It started displaying Error 22 after my wife Paused it for a while.
I check the error code meaning and it seem to be a drainage issue, so I followed Hoover advice on checking for any blockage and there were none.
I turn the machine off for 30 Minutes then gave it a try, It started draining the water for about 3seconds as normal then started feeling the water but as soon as it reached a certain level it started draining then feeling in a cycle of 3 seconds until error22 showed up again.
I checked the hose for the water level switch and is clear, I changed the water level switch but with no luck.
My finale conclusion is that the controller board is faulty as I can see no blockage neither in the inlet nor the outlet or the pump filter.
Has anyone experienced something similar?
Thank you.
What do you mean by "feeling?"
Edit,
Oh, "filling?"
Try it just on a spin cycle.It could be motor brushes or other things but see if it spins first.
I called Hoover Tech and they recon the circuit board is faulty.
I have singed up to there 12 moths repair&care.
They will send an engineer to fix it and if it's not fixable, they will just replace it.
Will keep you update as soon as the engineer give me a visit.
