I have an Hoover Washing Machine with a 1 pipe supply of cold water, which is now typically out of warranty, that has had regular problems with not taking in the fabric conditioner . Following visits by Engineers, it worked OK for a shortwhile, then returned to its troublesome self.The Engineer has since placed 2 restrictors in certain pipes, as a last resort, in order to increase the water pressure, but this has not worked.
Water pressure seems OK, and the draw holding the conditioner is regularly cleaned. When using these Comfort Conditioner pearls that are placed directly in with the load, no water is left remaining in the conditioner part of the detergent drawer, which is what you would probably think should happen on the basis that the conditioner was always left remaining in previous sessions.. Is there a sensor that can determine if any conditioner has been placed there, or not as the case may be, or is this another part of the problem.
