My Hoover Nextra wouldn't drain so I tried undoing the filter at the front on the bottom to see if I could let some water out but it only dribbled slowly. Is this normal or should a full machine pour water out when I undo this? I’ve checked the drain hose for blockages and it all seems ok.
I don’t really know much about washing machines but I would say it sounds like the pump is running when I run a spin cycle. By removing the filter I can see a spinning impellor behind it about 2 inches across, would this be the pump?
The only strange thing was a few small flat bits of white plastic in the filter that I’m thinking could either be something accidentally loaded in with a wash or internal parts of the machine. Could they possibly be pump impellor blades? The machine is only 18 months old so I wouldn’t expect these to fall off easily!
