My machine intermittently floods and I haven't worked out quite what the problem is - water pressure switch, programmer or both.
Is the water pressure switch, which should stop the machine flooding, a primary part of the programming or a secondary fail-safe device?
To be more specific does the programmer operate the water solenoid and then wait for the pressure sensor to tell it there is enough water before moving on to the next part of the program?
Or does the programmer operate the solenoid for a period of time. Then if the programmer gets stuck in between opening it and closing it the water pressure switch stops the machine flooding?
I assume it is the first and therefore I have an intermittent problem with the pressure switch. If it were the latter I would presumably have a permanent problem on the pressure switch and an intermittent programmer! Naturally one always tends to expect the single failure scenario!
Any other advice would be most welcome.
Clive
Clive
