I have just purchased a Hoover washer dryer model number WDM120.
The washer side of the machine is excellent however i've had a few problems with the drying side of it.
It was leaking when "drying" however the clothes weren't being dried. I checked on a site which said the TOCs might also need resetting on these machines.
Sure enough when I opened her up one of the TOCs (small peg-like components on the top side of the drying channel) had popped up and clicked when I pushed down on it.
I then removed a blockage from the chamber which converts the steam to water and pumps it out into the waste pipe.
I thought this would cure all my problems but all that happened was that the metal channel on the top side of the machine got red-hot again and tripped the TOC again.
I then noticed that when the dryer program was on the motor at the top of the machine connected to this channel did not rotate even though there was power being supplied to it. (the brown wire was live when on dry cycle)
When I check the wires when the machine is not on drying mode (i.e standy if you like,) both blue and brown wires are live.
Is this normal - Can anyone help me....?
Thanks for your time,
Dave.
Dave.
