Has anyone successfully changed the Drum Paddles on a Hoover WMH147DF/2-80 Washing Machine.
They are held in place by a single screw right on the line where the two Drum Halves meet, which is not accessible from the Drain Sump or Top Breather. The Drum also looks to be glued/welded together so no access possible by splitting the Drum.
Only way I was able to change them was to drill a hole at the top of the Drum to access the Screws and then reseal the Hole.
