I want to change over my old cast iron hopper head and cast iron down pipe ,which has about 4 waste pipes entering it,what is the largest black plastic pipe thay i can buy with a plastic hopper head,thanks.
Domestic use, normally a 68mm dia downpipe, but larger hoppers using 110mm pipe are available. (Hunter Highflo system is available in grey and black at that size.)
