Hi all,
I've just moved into a 1960 flat, floors and walls are all solid brick/concrete. I want to add some extra wall sockets. As I understand it normally you'd run the cable vertically down then under the floorboards and up at the new socket location. Now, having no floorboards, ideally I just want to chisel a channel in the wall horizontally to the new socket's position.
- Is this allowed?
- If it is do I need to protect the cable in any way other than putting it in a platic conduit and applying filler over the top?
- Is this allowed?
