i've just moved into a property that has a Horstman Diadem C/H + H/W control.
It's got the basic on/off, twice, all day, 24hr settings with a timer clock so you can set 2 on/off programmes.
I'd like to know if it's possible to change this for a timer that allows you to set more on/off times - a bit like my old central heating control where you had little 'pegs' around the clock which you pushed in/out to set the on/off times ?
is there anything suitable that i can use to swap this over ?
thanks for any advice.
