http://www.horstmann.co.uk/water-heating.php#Electrisaver
I know they are designed for immersion heaters but I also believe they can be used to "boost" the central heating instead of turning it on and forgetting to turn it off.
It is designed to be a double pole switch operated ON by you the user and OFF by the timer function.
So if you wish to wire it in parrallel to the central heating timer do you need to give the switch a live and neutral feed or just wire it direct to the terminal 1 + 2 of the boiler.
Does that make sense ?
