Hey guys, it seems like you are all very helpful, and as I know very little about central heating/boiler systems (I still can't figure out whether I have a "Fully Pumped" or "Gravity Fed" system), I thought I would ask for help.
Recently, the hot water and central heating in my home stopped functioning. Luckily for me the problem was relatively minor - simply put, the motor which made the ancient Horstmann 425 Diadem tick stopped ticking
I did a search on eBay and bought a Horstmann ChannelPlus H27XL.
This was supposed to be a direct replacement, simply clipping onto the identical backplate and giving me new functionality, with the ability to set different times for different days.
Unfortunately the seller made a cock up, and sent me a Horstmann ChannelPlus H37XL. One number makes a huge difference, as my system only has two "channels" - hot water and central heating.
The seller has refused a refund/replacement and PayPal has refused to refund my money as it is too small an amount (£30).
Anyway, I've been looking at the wiring diagram for the H27XL and comparing with the H37XL, and I'm trying to work out if I can use this 3-channel unit with my 2-channel system.
Having a look at those, does anyone think I should be able to use the thing I've got with my system? If so, what wires should I have to change?
My backplate/wiring looks very much like this:
If this isn't sensible for somebody with little experience like me, what should I do - cut my losses and buy a real H27XL? Or is there a cheaper alternative?
Thanks very much, Andrew
P.S - Almost forgot. Any hints as to how to find out whether I have a Gravity fed or Fully Pumped system? My boiler is a "Baxi Solo 3 PFL 50", there are two large rectangular tanks in the loft, plus one smaller one (maybe 1/4 the size), and there is a cylindrical (usually hot) tank in a cupboard next to my bedroom. (the house is a bungalow)[/b]
