Horstmann HRFS1 Wireless Thermostat Both Red and Green lights Blinking
18 Dec 2006
London
I have a Hortsman HRFS1 wireless thermostat. It's worked fine for five years but suddenly it seems to have developed an error. The red light(power) and green light (connection) on the receiver unit start blinking together and I can hear a faint clicking noise from the receiver whenever the heating should come on. Needless to say the heating does not come. The boiler seems to be fine as the hot water is all working.
Can anyone suggest what the problem might be? Has the unit packed up?
Many thanks,
Julian
Ahh, yes that would explain the clicking. Thanks very much. I've ordered a replacement.
Please report how you get on.
I have fitted the same thermostat to mothers house, I left it as a free standing unit, which was likely an error, I found if placed nearly out of range there seems to be no hand shaking so it can stick on heat, or no heat, and even when placed where it can set the base unit it is very slow to start controlling again.
However moving it around found that having it close to radiator worked better than away from radiator.
I wonder if my problems are due to too many items that are wireless in the house?
Sadly I replaced the receiver and the problem persists. So it's not the receiver....
By the way, ericmark, when my receiver was working I had a similar problem to yours. I suspected that the next door neighbours had the same unit which was causing interference. I changed the frequency that the unit uses by removing a jumper switch on the transmitter and changing the corresponding dip switch on the receiver, this fixed that problem. Instructions on how to do this are in the Horstman manual.
