Bought a wall mounted hozelock hosepipe this weekend and screwed it to the wall. Work perfectly except for leaks at the outside tap connection. I've used the plastic valve that came with it (white extension followed by yellow extension) but it's leaking at that point. Both have the washer in and both are new. What do you suggest? Changing the tap? Using a metal fitting? Etc?
Any suggestions? Thanks.
