Hot and cold shower only??
1 Sep 2021
Hi all,
hoping someone can help.
I had a orchard Wye thermostatic shower and recently the shower goes hot and cold. every other tap in the house runs hot water fine.
I changed the thermostatic valve but the problem still exists. I have boiler cover with Homeserve who are blaming the shower and said the new part is faulty, so I changed it again - same issue.
When the shower is turned on the boiler; Remeha Avanta exclusive 28c fires to 1, then 2 then then goes out. I have no idea what’s wrong?
Any helps would be appreciated. thanks
A radiator was moved in a bedroom around 1 meter about 2 months ago.
Does the shower valve require restrictor to allow combo boiler feed .
