Is it possible to have two quartz showers running off the same hot and cold feed ( cold from independent feed on tank and hot from essex flange). Was hoping to cut into the pipework that has already been run for the quartz shower that is already there.
either run new feeds is what i do to keep them both seperate and no chance of starving the pump of water
or
change the feed from the cws to 28mm then take your two 15mm feeds from that.
the hot water cylinder leave one 15mm feed from the essex flange.
and take the other 15mm feed from the 22mm outlet on the top of the cylinder or fit surrey flange or another essex flange.
if you take a 15mm feed from the dhw horizontal pipe on the cylinder make sure you take it down afew inches first.
what one are you fitting grohe, triton ,aqualisa etc ?
yes thats ok as they do reccomend it as one of the ways in their instructions.
but make sure you take any tee off the horizontal pipe downwards first.
or any pipe off the vertical pipe must be below the tee from the horizontal pipe from the cylinder.
I have just checked again in the cold light of day and the hot feed is actually in 22mm . Can this feed both showers? i will take a seperate cold feed from tank.
ive just installed a second aqualisa Hiqu taking the hot from domestic cylinder outlet upto the digi-box, 2 separate hot connections in 15mm off the 22mm pipe. on the cold side i teed into the 15mm tank connection.
